Took my BS for a lift install, and now throwing codes!
MyKindOfBS
Atlanta, GA
I took my BS into a shop that specializes in lifts, and the lift was installed and good, however the BS started throwing codes, I don't have the scan yet and they might be a bit over their ski's here, anyone have the same issue or some direction I can point them in? Example code: ABS, etc. Thank you!
golfmk6
jeeeeee
Los Angeles
jeep jl, tesla model 3
obviously code scanner. There's an iPhone app that's free, and cheap obd2 wifi scanner on amazon that's $15 that I've used for the past 5 years on my old Prius. Read the code and see. But likely if ABS they probably need to look at the BS again and fix and assess the issue. If I were in your situation I'd take the tire off and locate the abs and see. But if not take it back to them.
EDIT: Ok based on these two threads, take it back to them and have them fix it.
https://www.broncosportforum.com/forum/threads/sudden-abs-light-came-on-bronco-sport-wildtrak-badlands.11788/
https://www.broncosportforum.com/forum/threads/check-brake-system.7524/#post-133769
CLR
Chris
NorCal
I’d they unplugged any wires, make sure they plugged them in again. And a Bluetooth OBD2 scanner is cheap and easy!
golfmk6
jeeeeee
Los Angeles
Agree. I keep mine in my jeep it’s been around forever and helps out so many times. Our Prius throws codes due to the cat and it beats having to guess what it is. It’s impossible to know without reading the code.
MyKindOfBS
Atlanta, GA
The shop, and they are great, fixed it up. I honestly think they might have jostled a sensor and it reset on it's own. Anyways problem solved and I love the lift. Thanks!
