Rim Scratched Advise
Leeford
Lee
Ontario, Canada
bronco sport
Well I ran over a curb and the tire slide off making contact with the rim (ouch). The scratch/scrap in at the outer portion of the rim (did not touch the black) needs a cosmetic repair. Any advise on products to use?
Ford Bronco Sport Rim Scratched Advise PXL_20231114_145732891
cprcubed
Patrick
Parker, TX
Posting a picture of the damaged area might enable folks to provide more relevant solutions. Cheers!
BravoAlpha
Oklahoma
Replacement . unfortunately.
Depending how "bad" the scratches are you might be able to clean up the area using Scotch-Brite pads, they come in different grades of abrassiveness from fine to corse. I've used them before and for me I was at least 90% or more sucessful at removing the scratches I had, it was good enough my eyes wouldn't look right at the area that was scratched, add a little brake dust and the rim looked perfect.
https://www.3m.com/3M/en_US/p/c/abrasives/handheld/hand-pads/b/scotch-brite/
On the professional end there are a number or businesses that specialize in rim repair, this company is in Canada
https://www.leprecon.ca/services/rim-repair-wheel-refinishing
Or as a previous poster suggested, buy a new rim or possibly find a used take off.
Some of the rim repair businesses also sell used rims.
Quite a few options are available, all dependent on how much you want to spend and the level of "perfection" you want the rim to have.
Mrmike
Syracuse, New York 13219
Road rash is a very common problem. There are companies such as Rim Doctor who will repair damaged wheels. I've had 5 or 6 repaired over the years. Cost was about $100 t0 $150 each time. Talk to the local body shops or car dealers in your area. I'm pretty sure they have a local source for these repairs.
