Good morning all 21 Bronco Sport owners (22, 23 & 24 too). There has been several threads concerning noise, shudder, groan, etc. coming from the rear end. This thread is more specific. It concerns only the rear differential noise. This noise can sometimes be confused with rear brake noise which is a seperate issue and has seperate TSBs issued by Ford. The rear differential low speed shutter that you can feel usually happens when backing up and at low speed turns, usually to the right. I attached one official TSBs that document this and have a remediation listed to address it. There are a total of three TSBs for the issue. The link for these TSBs is at:
https://www.ford-trucks.com/forums/tsb_recall/tsbs/ford/bronco+sport/2021
For other TSBs scroll thru the list and you will find much more on other issue's. Sometimes the dealers (service agents) do not know of these so if you have an issue print the TSB that pretains to your issue and show them, that way there is no denial a problem has been identified and there is a fix for it.
