Powertrain fault/stability control issues
Wifes bronc
Matthew
Freeport TX
2021 bronco sport
I recently installed the 2” lift from flat out suspension and put bigger tires on my wife’s outer banks. The past 2 days she has gotten a service advanced track, the brake assist not available, powertrain fault, stability control, hill start assist and pre collision assist warnings/failures.
Had anyone else experienced this? Went with falken 235/65/18. Looks great on there but not if it’s going to lead to these issues.
Ford Motor Company
Dearborn
Bronco, Bronco Sport
Hello, I would like to see if I can assist you with your fault concerns. Could you please send us a message with your VIN and mileage?
StoneAgeMan
Seattle
Our brand-new Badlands threw all those errors, AND it also had turned on the ABS light. Note that if the ABS doesn't work, those features won't really work either (since they depend upon the computer controlling the brakes).
The ABS sensor was replaced, but that didn't fix it, so the Ford techs diagnosed it as a defective "tone ring" (part of the ABS speed encoder). They replaced the tone ring which fixed all those error codes. They actually replaced the whole hub, I suspect to avoid having to press out the old bearing, as the tone ring is basically part of the hub bearing.
Deleted member 12075
I’ve experienced similar twice in the year I have owned my BB, once before I swapped tires, once just before I had the PCM recall completed, but not since.
