Only 3 wheels turns on the 2 post lift
DMDS
Poland
Bronco Sport 23
Hi, I don't understand but maybe it's normal for BS Badlands. On the 2 post lift after put D or R gear only 3 wheels spin, front left stoping after few turns. I checked brakes, CV axle and it look like someting in gearbox make resistance for front left axle. After disconnect axle from wheel bearing I still feel some resistance for turn.
CLR
Chris
NorCal
You’re probably confusing the traction control by running it in drive with all wheels off the ground. In a low grip situation, it will try to send power to the wheel(s) with grip and apply brakes to the others.
