Loose steering (multiple culprits)
CFHall99
Chris
Boston
After driving my new BB for a couple days, I noticed the steering was really loose and felt a little scary on highway turns at 60-70 mph. The ride was also hard and felt like wheels were a bit unstable on sharp side-weight turns (like off ramps).
As most point out already the tire pressure was outrageous (47-49psi). Lowering that solved a lot of problems. But not the loose steering...
Went in settings and turned off Steering Assist. Also Trailer Sway Assist which is on (even though I didn't have the tow bar package).
Between combination of adjustments, my handling is tighter and more responsive...control and feel much improved.
Hope this helps if anyone experiencing similar.
PS - not sure if you want light steering and help going around turns if a BS is the car you'd be looking for. A sportier drive seems to be more fitting.
