How do I disable the 2 beep warning when exiting a running vehicle?
Altdalt
Paul
HugeGuyTheory
As of now, you cannot. Forscan will likely have this option available eventually, but I do not believe it is mapped out yet.
MKohlman
Monterey, CA
Bronco Sport Badlands, Fiesta ST
It should be possible in FORScan, but Huge Guy is correct, there is no "mapped" on/off function in the software yet.
However, it appears that someone on the FORScan forums has disabled it via a direct edit on the 1.5L and 2.0L current model Escapes. The code that did the trick is:
BCM 726-19-01 xxxx-xx0x-xxxx
If I get a chance this weekend I'll take a look and see if the setting is comparable on my Badlands.
As always, for anyone looking to get into making software changes in FORScan, I would thoroughly read their forums before making any changes. ?
