HEADLIGHT ASSEMBLY REPLACEMENT COMPATABILITY
BaseOrBust
2017 Ford Focus
Thinking about replacing the headlight assembly on my Base BS with one from a junked/salvaged Outer Banks/Badlands. From what I can see, the connections from the assembly to the wiring harness appear to be the same. Has anyone considered this or done it? If so, do any modifications need to be made.
Also considering the Oracle Colorshift DRL/Demoneye Kit once done.
https://www.oraclelights.com/products/oracle-lighting-2021-ford-bronco-sport-colorshift-rgb-w-headlight-drl-halo-upgrade
ChefDank
Nick
New York
I'm pretty sure the salvaged lights are pretty much a universal plug; maybe a fuse upgrade.
Careful on the oracle upgrade; you have to cut the headlights open to do it. So if you aren't confident in your skills I wouldn't recommend
