Fog lights issue?!
acslater
Hey all,
Anyone else experiencing fog lights issues? I have noticed once turned on from both being seen and then only either the right or left stays on.
Hey all,
Your fog lights are also cornering lamps. If you turn the wheel back and forth while in drive, you will see the corresponding light turn on. Center the wheel and they should both be off. This will only occur when the headlights are on.
There is also a switch so the fog lamps can be turned on to operate normally.
jsus
US
hmm
Sounds like you need to turn the fog lights on, otherwise they're acting as cornering lights as indicated above. Have you pressed the button in the middle of the headlight dial? Press that once and the fog lights come back on every time the headlights turn on, until you manually turn the fog lights off.
Petroph
Arkansas - United States
2014 FX4 F150
I was just about to ask this as well. Are you referring to operate normally where they stay off, even in a turn?
