Remote start fob for 2021 Bronco Sport, Big Bend model.
cutter57
SW Washington
I recently bought a 2021 Big Bend. I can remote start using the Ford Pass app, but my fob does not have a remote start button. Can I simply buy 2 OEM fobs with remote start and have them programmed, or is being able to remote start with the fob more involved than that? Thanks in advance for any help
MKohlman
Monterey, CA
Bronco Sport Badlands, Fiesta ST
It may be possible to do, but it will involve a bit of work. The Forscan community has a pretty well documented post on how to go about it:
REMOTE START - FORScan forum
At some point I'll likely give it a try, but haven't yet had the time.
Jocker
Trent
Redmond, WA
2023 Ford Bronco Sport
Is it possible to set up remote start with a BS base model? (uses a key to start instead of push to start)
bjbena
Barry
Escape SEL. EcoSport SES
It might be a bit of a nuisance as with the app it uses the built-in modem to initiate the remote start versus with the key fob it does not as it uses a version of a'line-of-sight' transmitter.
cutter57
SW Washington
I'm beginning to believe I will be satisfied using the Ford pass app to remote start the Bronco Sport. Thanks for all the input
cutter57
SW Washington
$177 + install sounds reasonable for the proximity and remote start
Thanks for your help, but I am now pretty content with using the FordPass app to remote start the car. So far, so good.
