Engine sputtering
wmcda
William
Baton Rouge
2021 Bronco Sport Big Ben
After getting gas my engine will drop a couple hundred rpm and shake before returning to normal has anyone else seen this or know what this could be.
Many questions:
Is this every time you get gas?
What brand of gas are you using?
Do you fill up each time?
Are you letting the pump shut off on its own?
What grade of fuel are you using?
How many miles are on the vehicle?
What engine do you have?
wmcda
William
Baton Rouge
Many questions:
Everytime I fill up
premium 93 usually from Sam's Club
I fill it up and let the pump shut off on its own
93 premium
74,000 mi
1.5L 2021 Big Bend
I assume there is no MIL (Check Engine Light) on the dash.
You may have an issue with the EVAP purge valve. This is a common issue.
This pulls gasoline vapors from the evaporative carbon canister and burns the vapors in the engine.
The purge valve assembly is located at the top of the engine and consists of small black tubes
https://www.oemfordpartsdirect.com/oem-parts/ford-tube-assembly-lx6z9d289sj
AndyMac204
Andy
are you doing alot of stop & go? or are you highway miles? id suggest a bottle of seafoam, injector cleaner etc next time you go for a highway run. get it nice n hot maybe you just need to burn off some carbon.
we are weekend road trippers, i'll pop a bottle of lucas injector cleaner in there every other tank. see if that helps.
Big Ben
Rick
Calgary
It could be the seal on your capless tank fill. Try cleaning it with WD40.
Jube
WI
23 Bronco Sport
By chance did this start happening after the last time you got fuel?
wmcda
William
Baton Rouge
No its been doing it for a couple months. Im going to try running some injector cleaner next time i take it out for a while on the highway
mikldom
Outer Banks NC
I can report that replacing these tubes will solve that issue. My OBX would stall out and be hard to start EVERY time I put fuel in. I had to push accelerator pedal all the way down when starting.
Purchasing this setup solved the issue. NO Purge Canister Code pops up anymore as well.
Here is the best price I could find with shipping. Price is a little more than the other link, but with shipping, this is best. Install not to hard either. Everything just pushes on, but you have to put tubes under other tubes.
FORD OEM LX6Z9D289SJ TUBE ASY - FUEL VAPO LX6Z-9D289-SJ | eBay
