Bronco Sport Makes the DST change itself.
Fordone Badlands
Ontario
22 Bronco Sport
This is the first vehicle I have owned that I have not had to manually adjust the time change for DST. What a pleasant surprise.
GulfCoastBronco
Topher
Corpus
Dang I wonder if you have a different setting applied. I had to adjust mine. ??‍♂??‍♂
BravoAlpha
Oklahoma
It should If you have automatic selected. It uses GPS. It also switches time zones on It’s own
I totally knew it automatically changed. Then I went and got in the car and it didn't adjust and the time was wrong, so I set it ahead 1hr. Then the car must have got enough signal that it also went ahead and I got to set it back an hour. So the lesson is that if you park in a garage, have more patience than me for the clock to adjust.
My 2013 lexus has an analog clock. Easy to change, but it doesn't do it by itself!
