Best Bang for your Buck Modifications?
OntheJob
Rochester, NY
2021 Ford Bronco Sport Outer Banks
Just took delivery today and so begins the mods. I'm not looking to lift, bigger tires or rims. Just great practical everyday modifications that are clever and worth it. Thanks!
Benanza
Ben
NJ
Tint the windows
Roof rack or platform
Nudge bar
Lighting
Smalls,
Get a smaller antenna https://www.amazon.com/dp/B01LZK5IRN/ref=cm_sw_r_apan_glt_fabc_P3377X6R3V4K05443PCJ?_encoding=UTF8&psc=1
There are great looking overlays for the interior to protect the finish.
Gear shift cup holder area:
https://www.amazon.com/dp/B09BFKJVKS/ref=cm_sw_r_apan_glt_fabc_T77AE7PYW6VJ087ATYDN?_encoding=UTF8&psc=1
Steering Wheel Panel Trim: https://www.amazon.com/dp/B09DGGZMKJ/ref=cm_sw_r_apan_glt_fabc_8KF62RER732VRNYCAFM8?_encoding=UTF8&psc=1
Window Trim Switch Panel: https://www.amazon.com/dp/B09BFJDDHB/ref=cm_sw_r_apan_glt_fabc_B2DAN1T3EE8CG8846D1V?_encoding=UTF8&psc=1
Make sure you have recovery gear, battery jump charger, first aid kit, roadside kit... There are a lot of things I can list just depends on what your using you're BS for. Hope this helps. Congrats and best of luck!
pinhotihiker
Jack
Cheaha
Bronco Sport Badlands Shadow Black
Storage tray behind screen (Yeepin brand on Amazon)
Center console organizer tray (Cosilee brand, Amazon)
Screen protector for center display
Drop Stop (fills the gap between seat and center console)
I think these are pretty functional and are really inexpensive.
SportWest
22 Bronco Sport Badlands
The "BabyBro Cargo Management System," first shared here. A few other posters and I blatantly copied this and it's worked great.
This setup goes above and beyond a typical after-market cargo organizer because the four expanded crates fit almost perfectly.
The only downside is that I have a few scuffs on the inside of the hatch from the crates rubbing or bumping into it. I don't care about that because the Sport interior easily scratches and really shows the scratches too -- just have to accept that and deal with it.
Blondie_jax
Funny…I know some same builds have different things (one of the forum posts here mentioned the two different start/stop buttons), but I have no space behind my screen like so many others do. Odd, as I was going to order one of those set ups, and thought I would share! ??
CrashBend
My choice of tire: General Grabber UHP size: 255 55 17 this leaves just about an inch clearance with this tire size. I do not have any lift kit. Still waiting to see what comes out in the aftermarket. Ford does not seem to hurry much for accessories or mods.
Good Luck.
Ford Bronco Sport Best Bang for your Buck Modifications? CAR1
Good Luck.
I thought that your bronco are 18 rims .
You are able to fit 255 on it. Good to know,I was concerned about 245. 65 17 .
Idontknow
Will
MN
Cross trek and grand caravan
A lot of mods covered. Here’s some practical things to make sure you have with you maybe?
Tire pressure gauge with tire deflater so you can air down if necesssary. Make sure you get one that covers the max psi.
https://www.amazon.com/gp/aw/d/B01J580F2K?psc=1&ref=ppx_pop_mob_b_asin_title
Portable air pump this little guy is great and plugs right into your 12v outlet.
https://www.amazon.com/gp/aw/d/B01L9WSTEG?psc=1&ref=ppx_pop_mob_b_asin_title
headlamp in case you need to change a tire in the middle of the night. I prefer a rechargeable usbc one so I don’t have to keep extra batteries in the car. The car does have a usbc charger after all. Fenix makes some great headlamps for this.
This is just a best bang for the buck
https://www.fenix-store.com/fenix-hm50r-multipurpose-led-headlamp/
Small wrench sized to your battery terminals or an adjustable wrench.
Window breaker seatbelt cutter
hammock or small collapsible camping chair. Sometimes it’s nice to just go hit up a park and sit out and I don’t have to remember to load it up. I keep a cheap one I got on Amazon with me. I use the one I linked below for that. They work great. Not as well built as my Helinox one but I’m 225 lbs and holds me just fine.
https://www.amazon.com/Sportneer-Portable-Lightweight-Folding-Backpacking/dp/B01N67GCKW/ref=mp_s_a_1_3?crid=132LM7OPBYPFT&keywords=collapsible+camping+chair&qid=1638376407&sprefix=collapsible+camping,aps,99&sr=8-3
I like gadgets so this is where my mind goes when I think of mods. Grats on the delivery!
Idontknow
Will
MN
