Auto Window Up: rear drivers works at times...
Leeford
Lee
Ontario, Canada
bronco sport
I've had this issue since May. I can reprogram it by doing the up and hold. This does resolve the issue for the time being but it will stop without notice. I can't figure out the issue. I called ford and they will want to see it in two weeks...if it's still acting up.
Any ideas out there?
Fossil
Ernie
ohio
just guessing but there may be a bind in the mechanism or window track that fools the brain that the window is blocked. My wife's Escape did that and some silicone spray in the window track cured it.
VirtualJMills
Jason
California, US
There's separate learning for bounce-back and auto-up/auto-down stop points. I didn't realize they were wiped with battery disconnect (and I assume under-hood fuse-block disconnect).
2021 BRONCO SPORT Owner’s Manual
Second Edition (January 2021)
Bronco Sport (CHD) Canada/United States of America
Pages 88 + 89:
One-Touch Down (If Equipped)
Press the switch fully and release it. Press again or lift it to stop the window.
One-Touch Up (If Equipped)
Lift the switch fully and release it. Press or lift it again to stop the window.
Resetting One-Touch Up
Start the engine.
1. Lift and hold the window switch until you fully close the door window. Continue to hold the switch for a few seconds after you close the window.
2. Release the window switch.
3. Press and hold the window switch until you fully open the door window.
4. Release the window switch.
5. Lift and hold the window switch until you fully close the window.
6. Test for correct window operation by carrying out the one-touch down and one-touch up features.
Rear Window Lock
Press the control to lock or unlock the rear window controls. It illuminates when you lock the rear window controls.
Bounce-Back (If Equipped)
The window stops and reverses if it detects an obstruction.
Overriding the Bounce-Back Feature
Pull up the window switch and hold within a few seconds of the window reaching the bounce-back position. The window travels up with no bounce-back protection. The window stops if you release the switch before the window fully closes.
Resetting Bounce-Back
If you have disconnected the battery, you must reset the bounce-back memory separately for each window.
1. Lift and hold the switch until the window is fully closed.
2. Release the switch.
3. Lift and hold the switch again for a few seconds.
4. Release the switch.
5. Lift and hold the switch again for a few seconds.
6. Release the switch.
7. Press and hold the switch until the window is fully open.
8. Lift and hold the switch until the window is fully closed.
9. Release the switch.
10. Open the window and then try to close it using one-touch close.
Note: Repeat the procedure if the window does not close when you use one-touch.
Leeford
Leeford
Lee
Ontario, Canada
bronco sport
Pages 88 + 89:
Start the engine.
Rear Window Lock
I went to the dealer and they scanned the OB. They corrected what ever was going on...so far so good.
VirtualJMills
Jason
California, US
I wonder if there was a behavioral tweak made to the logic in the associated control modules' firmware that made it into later editions, but didn't warrant a TSB of its own. Perhaps the default torque-limit sense level during auto-close was too close to "typical" drag of a window in the wild, or similar.
