- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,166
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Some background: I try to drive as smoothly as possible. One of the ways I do that is to progressively reduce brake pedal force as I slow to a stop. If done correctly, the car will not rock backward on its suspension after coming to a stop--that's the "smooth" part. I brake smoothly enough that sometimes—especially stopping on an uphill slope— pressure on the brake pedal isn't enough to activate the auto hold feature. Additionally, and seemingly unrelated data: the engine auto start/stop system in my car doesn't activate very often. I assumed it was due to the weak battery issues so many have reported, and I've been anticipating a battery failure.
With all that in mind, I noticed something interesting the other day. As I was sitting at a traffic light waiting for it to change I got a text. I use the auto hold function, so my right foot was on the floor, and the auto start/stop system had not activated—the engine was running. I was between destinations, so my phone wasn't plugged in. The light had just changed, so I knew I had time to quickly check my phone. As I was looking down I didn't see the left-turn signal change, and the car sitting to my left started slowly rolling forward. I got that weird sensation that it was my car rolling backward, and I immediately tromped on the brake pedal. Of course, I wasn't moving at all, and after laughing at myself I took my foot off the brake pedal...and the engine shut down. I thought, uh oh, my battery's dead! But nope, it was just the auto start/stop system.
Turns out you have to step much harder on the brake pedal than I normally do to activate the auto start/stop system. If you think your auto start/stop system isn't working properly you just might try briefly stepping harder on the brake pedal. It's worked for me every single time I've tested it over the past several days.
BTW, my car has is just over two years old with +20K miles on the ODO, and apparently the battery is fine.
