2025 Rally Lights with Toggle Switches - Anyone done it yet
The_Jimmer
Georgia
2025 Badlands Sasquatch / Desert Sand
Just like the title says...anyone put any lights on a 2025 and wired them to the new toggle setup in the overhead? I want to put something like KC lights off the front bumper behind the pushbar but other than that less than useful schematic that's floating around, I can find nothing helpful for an install.
The_Jimmer
The_Jimmer
Georgia
Are you looking for the wiring info .. location of the wires under the hood along with the amp rating of each of the 4 circuits? That info is posted on the forum
Or are you looking for lighting products and ideas?
that's the article I've seen...it's more of a "here's where to search" than a guide. and yes if anyone's done anything involving lights on a 2025 using the switches and installed wiring I'm interested in feedback on that as well as anything that fits on the '25s using the existing bronco bolts or hardware developed for the '25s. and yes i've browsed what's here already...and it's pretty much pre-25 setups or not using the installed toggle switches.
See if these are sufficient to locating the wiring under the hood:
If it’s not the wiring info you find helpful probably the two owners that posted the info at these links can assist
Also I don’t recall seeing specific posts about products that fits on the '25s using the existing bronco bolts or hardware developed for the '25s so can’t help you there
Basically is the same info, at least one of them with a video
Both will say “…remove both front tires and fold back the liners: …we were able to remove a couple of the securing clips and by carefully folding it back to expose the wires, we did not have to completely remove the liner but we did have to remove both front tires. (Use jack stands and extreme caution when working in this area!)”
1.
https://www.broncosportforum.com/forum/threads/bl-sasquatch-aux-switches-wiring-guide.13923/post-238127
2. https://www.broncosportforum.com/forum/threads/does-anyone-have-a-tutorial-video-or-photos-for-the-aux-switch-wire-locations-for-2025-bronco-sport.14101/post-252098
The_Jimmer
The_Jimmer
Georgia
1.
Thanks. Had the one with the schematics, but not the video. Def helps!
