Status
Not open for further replies.
Flatout Suspension
Gold Sponsor
Maryland
www.flatoutsuspension.net
2022 BS OBX
Our next batch of 10 arrived, 6 have gone out, 4 are in stock as of right now. These things go FAST, so don't dilly dally! We are currently running a sale too, so you will see the discount in your cart at checkout!
See the 2" Level Lift Kit here
Bronco Sport 2 Inch Level Lift: (Fits ALL Bronco Sport trim levels)
Here's a review on the Bronco Sport Forum
This entry-level lift kit allows you to lift the front of your Bronco Sport 2" and the rear 1.5" for a level lift. The rear is on a height adjustable perch which will allow you to do a 2" lift front and rear and retain the natural rake (0.5" higher rear) for a true 2" lift if desired.
The front uses a 2" (50.8mm) spacer that sits atop the OEM strut. The rear uses a height adjustable spring perch and new springs. You can choose between a comfort spring which retains the OEM rate and load capacity or an overload spring which increases load capacity perfect for hitch mounted cargo baskets or rear tire carriers eliminating sag.
Kit includes:
2x 2" Front strut spacers
2x Sway bar endlinks
2x Camber adjustment bolt
4x Rear trailing arm spacers
2x Rear Springs (comfort or overload)
2x Height adjustable rear spring cups
2x Flatout Suspension decals
OPTIONAL Subframe Spacer Kit (RECOMMENDED)
Approximate install time : 2-3 Hours
CUSTOMER REVIEWS:
Brian B
on Jun 26, 2023
"This thing is incredible. High quality parts, design, and looks are apparent from the time you open the box. The guys at my shop could not believe what was put into this compared to other lifts at this level. The customer service was TOP NOTCH throughout the process. HIGHLY recommended!!"
Why buy our kit instead of the others on the market? While spacer lifts all serve the same function, most of the kits out there only lift 1.5" and do not allow you to level the ride height. Our spacer is slightly offset to maintain proper camber and caster to prevent tire wear. Other spacer kits do not accommodate a way to increase cargo/ load capacity as they reuse the OEM rear springs.
If you set rear height above 1.5", we advise adding our subframe spacers as well to re-center the rear tire and reduce the angle of the CV.
Suggested tires: 245/70/16, 245/65/17, and 245/60/18
DesertRat19
Will
Phoenix
Anybody put this on a badlands? Are bigger wheels an option with this kit of so?
Status
