Rear wiper doesn't move but motor is turning
CaptainCanada
I have a 2021 BS Outer Banks
I noticed my rear wiper wasnt turning so I went to lift the glass and I can see the rear motor is rotating back and forth but if i close the glass and try, the wiper doesnt move. I also noticed that If I try to open the lift glass after having attempted to use the wiper and then shutting it off i have to really pull to open it which makes a ping sound.
Where as if I then close it and unlock it again it opens easily up like it always did until I've tried the wiper again.
Any thoughts? Doesn't seem like motor but I'm not sure what else to really look at? Trying to avoid garage repair costs if its something I can just do myself.
UPDATE: Seems like the arm itsself is seized, popped by the dealer and we looked at it and with some cutting fluid and lube was able to get it moving again and going back and forth but it still seems seized between the 9 and 10 o clock position and they suggested taking it off and cleaning off with a wire brush or something whatever debris is causing restricting it there. Might be something I can do myself when I have time to take it off and see whats causing the friction in the arm. It at least moves now though im not sure how this has exactly happened unless something from the heat and humidity recently has caused it.
zl7cw
Jon
Ohio
2021 Bronco Sport Big Bend
I'm dealing with exact same thing now!
CaptainCanada
CaptainCanada
I havent had the issue return since doing what we did. The plastic cover can pop off and they used a bit of rust cutting fluid and let that soak down with the glass in a flat position and then wipedoff and sprayed some lubricant grease and let that soak down. and we just rotated it back and forth to work it in. With the glass up you should be able to just turn the wiper by hand back and forth. Mine was most stiff towards the drivers side. It had to sit about 24 hours before i noticed it actually fixing the problem. Tho I applied more rust inhibitor spray/lubricant the next day and its been fine ever since. That was just over a month ago.
