- Thread starter
- #1
Id like to see how you guys ran wiring.
Yes, please and thank you! Trying to see how it can be done without drilling holes or seeing wires on the outside if possible.Id like to see how you guys ran wiring.
I believe I read in the manual on the BL and FE there is a harness connection in the front of the raised rails for the OEM 40" barYes, please and thank you! Trying to see how it can be done without drilling holes or seeing wires on the outside if possible.
This seems to be a good starting point, at least for Bandlands editions where the appropriate wiring pair is known to be present: https://performanceparts.ford.com/download/instructionsheets/IS_M-15200K-CXR_022321.PDF
As I mentioned in this thread, https://www.broncosportforum.com/forum/threads/auxbeam-6-gang-switch-panel-where-to-hook-up-the-base-unit-acc-connection.3860/post-64880
… it's a pretty involved process, but has some interesting data in the documentation.
FWIW, I haven't personally installed any lights at present.
Wow, glad to have that option, but that reminds me of when my dad did a frame off restoration on his ‘67 Corvette.… it's a pretty involved process, but has some interesting data in the documentation.
