It is a Base model and the back window is in fact tinted, I guess not as dark as other trims.Maybe it is a base model and the glass has no tinting? Just a guess.
Base model:It is a Base model and the back window is in fact tinted, I guess not as dark as other trims.
Base model:
Big Bend and up:
So it looks like the dealer put on aftermarket window tint which is applied to the inside of the windows. That's why the rear window defrost looks different from the outside compared to factory tinting.
May well be.So it looks like the dealer put on aftermarket window tint which is applied to the inside of the windows. That's why the rear window defrost looks different from the outside compared to factory tinting.
While you're at it you could remove the dealer's decal.Here you go. I haven't removed my letters, I just photoshopped them out so you can see if you like the look..
