I like the matte on gloss look.
Because I want to live in a NORMAL world again...well pre 2020Why would you care?
Then wear your mask dumbass...Because I want to live in a NORMAL world again...well pre 2020.
How painful were these to put on? Thinking about doing someI finally got around to applying my black vinyl letters from Vortex Signs. They look amazing!!!! Thank you @VortexSigns! Great product! I’ll definitely be back for more graphics, and certainly for some Cyber Orange Bronco letters when my 2DR arrives.
Not bad at all for the big letters. The “Sport” is all on one backing so it’s a bit trickier but only took a few minutes. Totally worth it.How painful were these to put on? Thinking about doing some
OK so are these decals where you need to wet the surface?Not bad at all for the big letters. The “Sport” is all on one backing so it’s a bit trickier but only took a few minutes. Totally worth it.
Nope, no wetting. The letters have an adhesive on the back.OK so are these decals where you need to wet the surface?
Not that it matters now...had you cut the "sport" apart and applied one at a time it may have been easier (go blue)...it still looks great.Not bad at all for the big letters. The “Sport” is all on one backing so it’s a bit trickier but only took a few minutes. Totally worth it.
I used oracle film on mine very easy to use. Should have a clear transfer film and you just line up the decal, press into place and smooth out with credit card or plastic squeegee. If you have bubbles poke with a pin or try to move the bubble to the edges.OK so are these decals where you need to wet the surface?
HA! Yes, after the fact I realized cutting and applying separately would have been much easier. Lesson learned for next time.Not that it matters now...had you cut the "sport" apart and applied one at a time it may have been easier (go blue)...it still looks great.
That looks so great!!!Added a few more today![]()
