- First Name
- Gerardo
- Joined
- Jan 5, 2021
- Threads
- 29
- Messages
- 175
- Reaction score
- 223
- Location
- Durham, nc
- Vehicle(s)
- Bronco Sport
- Thread starter
- #1
I love how they referenced the people arguing about it on this forum ???.
I believe the BL/FE PTU is liquid-cooled (engine coolant). I did also read about testers overheating in extended *sand* play, as ought to have been expected. The system tells you (and I think eventually disables 4WD), you take a break and resume after some minutes. Still I think heat = wear/damage over the long term. At least Ford built in these bits of protection, the PTU is already in a vulnerable spot anyway. I'm curious to see what this PTU looks like v. the Escape, etc.Just so people have a better idea of the type of situations it will overheat in. It's not going to be from rock crawling or driving along regular dirt roads. All wheel drive systems struggle with overheating when doing two things, climbing continuously through loose soil or aggressive driving through sand. It's not very often most people going to have trouble with these overheating.
You can combat this a number of ways. One is to use larger PTUs so they don't slip when sending power to the rear. Another is cooling them either with air or liquid. Another way is a low range transfer case.
All the models of the Sport have some form of cooling on these units so they'll do better than most all wheel drive vehicles in this category.
If you are talking about the recent Ford recall . I think it was 1,066 vehicles.I thought this was bring up an old issue. How many of these were in the low differential oil recall?
