How to remove exterior trim pieces
FleaBeard
Todd
2024 BS BB, 2024 Ford Escape
I want to wrap all of the piano black pieces around the windows. It's much easier to wrap them off of the vehicle. Anyone have advice on removing all of them? I know the A Pillar is super easy but the rest may be a bit tricky so I figured I'd ask before pulling interior trim to look for fasteners.
cprcubed
Parker, TX
I know that the C pillar pieces are not "reuseable" (glued in???). They are not cheap either. My driver's side had to be replaced when the rear quarter window was replaced (due to an unknown object shattering it - $900+ total). Cheers!
FleaBeard
FleaBeard
Todd
Glued in.... that's special. Thanks Ford.
mbeckm
PA USA
FleaBeard
FleaBeard
Todd
Curious what you're going to be wrapping them with? I have something I'm curious about. You can buy a wrap.
For example: https://www.undergroundgraphics.com/products/bronco-sport-a-c-pillar-graphic?variant=44215794925807 However, the thing I'm curious about is why not just sand down the piano black pillars to the degree of satin or matte that you desire? Has anybody ever thought of doing this or actually done it? If so, could you show what you've done? Thoughts please.
Using this because it's pretty close to the look of the factory grill material. https://vvividshop.com/products/2019-vvivid-matte-metallic-black-ghost
I guess you could sand, but I'd be afraid of getting inconsistent results across all of the pieces.
Mwittke5857
Elma, NY
2021 Bronco
I went the Underground Graphics route. B4 you ask, my rig goes through a brushless automatic car wash at least twice weekly. No issues whatsoever after nine months.
Ford Bronco Sport How to remove exterior trim pieces Drivers_Side_11-24
Ford Bronco Sport How to remove exterior trim pieces Flag window
FleaBeard
FleaBeard
Todd
I may give up and go that route. Looks good.
Mwittke5857
Elma, NY
2021 Bronco
Cleanliness is next to Godliness. I washed the areas with a drop of dish soap in a sprayer, followed up with Prep-Sol, then 90% alcohol. Outside isn't ideal but I was lucky it wasn't windy the day I applied them.
