Headlight stays on after aftermarket light kit installed
KrisT
Kris
2023 Ford Bronco Sport
Where are the headlight relays located? I put on side marker lights and now the passenger headlight stays on? Any help will be appreciated.
Have you tried removing the side marker lights to see if that fixes the issue? If so, then there's likely something wrong with the way you wired it.
KrisT
KrisT
Kris
I fixed it…. I had one pin crossed over to the hole next to it- it wasn’t making contact. I changed out the pigtail, spliced the SML wires correctly. Taped them with friction tape. All is good in my world now.
