kennyroo
Kenneth
San Diego
@kennyroo that is a fantastic looking set up. How do you get the doggies in the upper tent??
Thank you , they don't go in the upper tent. They sleep in the annex. It's fully sealed, We just zip the main entry way closed and leave the window cut outs open for ventilation
TRWXXA
Chris
Indianapolis
2023 Bronco Sport Heritage Edition
Looks good ?. Lots of clearance under the liftgate for that one? I checked out the Ecarzo one others here have used but it's too thick
Yes. It's just a plastic applique about 1 mm thick. But if you expect to really need heavy protection you might want something thicker, and that wraps around the edges.
Spartan007
Jacksonville
Put the Ford, rear bumper protectors on both BSs.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20231011_155051
How is the adhesive? I've tried multiple aftermarket ones due to how much cheaper they are. They have been very disappointing though due to the adhesive wearing off rather quickly.
jkeaton
Greatest country on earth!
This one
Now do the same thing on the way home in Normal mode; betcha get the same mileage.
That’s my plan and I don’t doubt it won’t change. I’m trying to chase the elusive 30 mpg that everyone says they get. It’s a data driven experiment. ?
Sldavid
Sankalp
I am more of an KMs/L person. Went on a trip and got 13.4 kms/l which is equivalent to 31.5 mpg. This was on normal mode.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0382
SeaJay
Georgia
2023 OBX Sport, Area 51, Hitch, Assist++
Yeah, I’m one of the lucky ones in my 23 OBX with original Michelin's on. I always get well over 30 on my long highway trips. Cruise control most of the time set at 65-70 max. Sometimes I remember to do Eco but mostly Normal mode.
TRWXXA
Chris
Indianapolis
It's a pretty strong adhesive. Time will tell.
It's all about the surface preparation, though. You gotta get all the wax and oil off the bumper.
21,800 miles and got a fast blink. Changed a rear brake light bulb to solve it. Considering how much of that mileage was open highway, that's really poor bulb life IMO. Luckily I already had a 3157 in the drawer. Boo to Ford for making the rear lights come out with those spring clips.
Anyone that hasn't had to do this, it's easy and you can find how to videos. But you have to pry off the rubber trim piece between the light and hatch(with the metal clips), then take off two 10mm nuts holding the light assembly that come set from the factory at seven ugga duggas. Don't even reach for a nutdriver. I had to put it away and get a 1/2" socket and extension. The light pulls out from the outer body side with two more pushpin assemblies.
