Flatout Suspension GR Plus - ONE in stock
Status
Not open for further replies.
Flatout Suspension
Gold Sponsor
Maryland
www.flatoutsuspension.net
2022 BS OBX
Just a heads up, as of writing (this can quickly change), we have one of our GR Plus suspensions available for a Badlands/ First Edition/ Heritage available. No wait time. Just need to print a label, print your unique paperwork, and close the box. We are including subframe spacers FOR FREE, and giving an instant discount of 10% at checkout. You'll know they are no longer available when it says "sold out". Hurry up though, these are crazy popular and this is a great deal!
https://flatoutsuspension.net/products/bronco-grl-stock
*Pictures are slightly out-dated as they were prototype pictures
Tigger
Tigger
Illinois
I don’t care to belabor the point to you, but a Heritage is a 1.5 like the Base, Big Bend and Outer Banks whereas the Heritage Limited is like the First Edition and is a Badlands. So for your vernacular, Base/Big Bend/Outer Banks/Heritage vs Badlands/First Edition/Heritage Limited. The difference of 1.5 to 2.0 may not matter to you, but the latter group already has a 1.5” lift which you should deem critical.
But more important to me, is there a way to find a local place to install your products? Here in Central Illinois, I am not having much luck.
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
I don’t care to belabor the point to you, but a Heritage is a 1.5 like the Big Bend and the Heritage Limited is like the First Edition and is a Badlands. So for your vernacular, Base/Big Bend/Outer Banks/Heritage vs Badlands/First Edition/Heritage Limited.
Yeah I always screw that up.
For installs, try the dealer, a few dealers have done them for people. It’s really just a shock swap, nothing crazy. We provide thorough instructions too (you can get it right on the site).
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Yes you do so edit your original posts so you don’t confuse people, would be my suggestion, repeatedly. Unfortunately, I keep being told no on the install. Thank you for posts and your product, and it is something I am interested in, but just not working for me locally.
Where abouts are you? I’ll see if I can help find someone.
Lufelham
Luis
Mexico
Bronco Sport Badlands 2022
Sorry for my ignorance but can you combine the subframe spacer and the new suspension? What is the max inches I can gain with that on my badlands I have a 1.5 inch RC spacer lift and bigger tires that give me 0.5 inches so with this can I get 3+ inches if I remove my spacer lift and get this?
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Just for clarity, a subframe spacer drops the rear multi-link subframe to offset the geometrical changes after lifting. It doesn't have anything to do with height. I think you're thinking of your common lift (adding height) spacers as you mentioned 1.5 RC spacers. So to answer both - you can use these subframe spacers on any lift and it's recommended over 1.5", and you can combine lift spacers to get even more height (but you won't need them). Our GR models (Lite, Plus, and 40) will easily max out the limits of the Bronco sport. I think most of our Bad Lands customers set them for 2.5" lift.
Ford Bronco Sport Flatout Suspension GR Plus - ONE in stock image0_6_482f8321-b1f0-495f-8c2a-97c0d871e43c_480x480
Lufelham
Luis
Mexico
Thanks a lot for the reply and the information new to this world and lots of things to learn
Status
