Stock tire status at 41k miles
BravoAlpha
Oklahoma
At @34,000 my Falkens have even tread wear and still not to the “wear marks”, but getting close and I’ll probably change ‘em out before summer (long trip planned). I do rotate them front-to-rear every 5,000 miles.
I’m in the same position. I think mine will go past 40k but not 50.
I’m headed out west and if I go solo, I’m taking the BS. That will mean a new set of tires. If the Family, or some of, goes with me, I’m taking a bigger vehicle so then the Bronco stays local and I’ll let the tire wear play out.. I’d like to see how far they go.
BravoAlpha
Oklahoma
You shouldn't need alignments as regular maintenance, just tire rotation if your needing alignments something is off on the suspension. I have only had alignments either after an accident and they had to replace a sub frame or suspension parts or I did a lift or some change to the suspension geometry.
I wish that was the case. But often it’s not. My Silverado has had 3 alignments for no reason, the first time I wasn’t even aware of a problem. I’m going to have all the vehicles checked although I don’t see signs of anything. It’ll getcha
