Is Caster Adjustable?
Bluebaru
With the use of over sized tires causing rubbing, in the front, at the pinch weld, for everyone(?) I'm wondering if caster is adjustable or if anyone makes a caster kit that might be able to create a little more room, without having to trim the fender liner or pinch weld? I'm hoping to be able to use a 235/70/17, 30.0" diameter tire on a 17x7.5 +40 wheel. My thinking is also that low offset wheels will make the issue worse.
