Rear Quarter Window Graphics
Budstang2k5
Bud
2022 Bronco Sport Badlands / 2018 Ford F150 5.0
Purchased and applied the Bronco / Flag graphic from Diamond Vinyl Graphics. Got it with the install package. Watched the video on YouTube and followed the directions as shown. Left the vinyl on there for approx 40 minutes before I removed the backing and it still had some spots that were stuck to the glass but it was minimal and easily tacked to the glass during removal of the backing paper. I have bever done this before so it was a new experience. I wasn't able to see thru the backing paper like the video showed but did my best to press everything and squeegee out the fluid and bubbles. Zero bubbles on the finished application. Alignment was a little bit of a challenge as it didnt slide like the video, maybe I didnt use enough fluid..... Recommend when removing do not start at the tip of the angle, remove as shown in the photo here.
Ford Bronco Sport Rear Quarter Window Graphics 20220730_115937
Ford Bronco Sport Rear Quarter Window Graphics 20220730_115943
Ford Bronco Sport Rear Quarter Window Graphics 20220730_124540
Ford Bronco Sport Rear Quarter Window Graphics 20220731_094631
Ford Bronco Sport Rear Quarter Window Graphics 20220731_094646
CallMeBill
2022 Carbonized Grey Badlands
I had the same experience with their decals. I think they could have used a clearer tack rather than the paper one. Very hard to see thru it and check the alignment.
gcbroncosport
G
MA
Thanks for the tips! Thinking to get one too... Maybe having a light inside the cargo area shining outward on the window pane will help with seeing the graphic to align it? Do you think that would work/help?
Budstang2k5
Budstang2k5
Bud
It is tinted so it would probably have to be bright. Maybe a bright LED
SapphireCat
Catie
When I did mine, I trimmed much closer to the decal than it was shipped so I had a better idea of window placement when I started. I also recommend using more fluid than you think if your window is hot from sitting in the sun because the vinyl adheres pretty quick on a hot surface.
The light idea isn't bad - I could open my hatch and see from the inside of the car where the decal was - but you can't see the entire window from the inside, so just keep that in mind.
My tip is just take your time and go over it with the squeegee several times, in all directions. I left mine on about 30 minutes each before pulling the tack paper; pulled slowly but firmly and it went well!
Pics: (finished, from the inside, and from the outside)
Ford Bronco Sport Rear Quarter Window Graphics 20220807_234626637_iOS (2)
Ford Bronco Sport Rear Quarter Window Graphics 20220807_225921387_iOS
Ford Bronco Sport Rear Quarter Window Graphics 20220807_225902157_iOS
