Interior window trim
Mac G
Ellicott City, MD
Anyone know how to remove the plastic trim that goes up and around the 2 front windows on the interior side? I'm hoping it comes off without removing the whole door panel... Bought a pre-cut tint kit to match the front windows to the back, and I'm thinking the install would be way easier with that out of the way. It would be this piece- https://encrypted-tbn2.gstatic.com/shopping?q=tbn:ANd9GcT43pVTraJz4Yu68APRT6FrOp064VHtFzrppgxUAJ7koGvwg1C_vpS3iD9DuYfmlY_SsHH6wXzatAAebeajh9q7gy772Io7vHN9prTLF4AmZPa4r-FF1ZGl
Thanks in advance!
R W NORRIS New Mexico
Rodger
New Mexico
Bad news my friend. If you note on each end of the piece you show there are "anchors" that attach to the inside of the door glass channel. Are you going to use the "dry" or "wet" method for the install? If the wet install, you may insert the tint into the bottom of the window with a "putty knife" while it is still good and wet. Just a tip, do not run the tint all the way to the edge of the glass. Leave about 1/4" all the way around, otherwise it will start to peel after just a few weeks. Also if using CERAMIC tint, do not use cleaner with amonia or it will crack. Good Luck. ROdger
