- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 101
- Messages
- 5,315
- Reaction score
- 9,988
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Hey Admin, if you think this is off-topic please just move it to the off-topic forum. I think there may be implications for Bronco Sport owners.
I watched the video below yesterday from a Ford tech working on a full-sized Bronco with a damaged transfer case. If you watch carefully, he says some things I found very confusing, especially regarding choice of 4WD mode. Here's the video:
The tech claims that driving the Bronco with 4A selected is bad for the vehicle, and can result in loss of warranty. I'm not sure I agree with him. There are warnings in the Owner's Manual similar to those in the manual for the Bronco Sport about driving on dry pavement with 4WD locked in. The BS manual says doing so can damage the clutches used in the power transfer unit (transfer case in the video) and the rear differential.
What's confusing is the tech in this video seems to suggest that use of the 4A 4WD mode is under the same restrictions. However, I've found several sources online that say 4A mode is essentially the same as the intelligent 4WD system in the BS in that it automatically adjusts power based on conditions, and is perfectly suitable for use on dry pavement.
The full-sized Bronco manual states:
So how does this apply to the Bronco Sport? I think it highlights the importance of owners knowing their vehicles. Sometimes you see a YouTube video by a "Ford Technician" and you think, "Gee, he must be right." Well, maybe not. You should thoroughly understand the restrictions and limitations of the systems in your vehicle so you can argue intelligently with service techs, who are clearly not infallible.
It also highlights the fact it is possible to damage your vehicle if you don't operate it properly. I'm fairly certain the transfer case in this vehicle was not damaged by the owner's use of 4A mode, but there was clearly a great deal of stress placed on the component at one time or another. It may have been extended use of 4H or 4L on dry pavement, but I tend to think it more likely that something the tow company did is the culprit.
Regardless, you can avoid damaging your car by following the guidance in your owner's manual as it applies to the 4WD system: don't manually lock the system in 4WD or select a drive mode that locks 4WD or the rear diff if you are on dry pavement.
Four-wheel drive auto provides electronically controlled four-wheel drive power to both the front and rear wheels, as required, for increased traction in varying on-road conditions.
That sounds to me like Ford expects owners to use 4A in situations where conditions might be changing. There are no restrictions I can find saying that 4A cannot be used on dry pavement.So how does this apply to the Bronco Sport? I think it highlights the importance of owners knowing their vehicles. Sometimes you see a YouTube video by a "Ford Technician" and you think, "Gee, he must be right." Well, maybe not. You should thoroughly understand the restrictions and limitations of the systems in your vehicle so you can argue intelligently with service techs, who are clearly not infallible.
