Buzzing Sound from the Windows - Sound System
mok968
NB | Canada
Hi Everyone,
i have a 2025 Outer Banks with the 10 speaker system. Loving the car so far. However I have started noticing buzzing noises coming from the door when there is bass. It seems to go away every now and then, when I put the windows down. Seems like its the windows resonating. Apart from this, i sometimes hear the buzz coming from the seat belt area.
Does anyone else have this issue or a potential solution for this?
Thank you and have a great day!
SHAKEmeBUNS
George
2022 Bronco Sport Outer Banks
Ford's are notorious for crappy door panels. The rattling is coming from the hard plastics on the handle.
My Ford fusion did this. I took the panel off and put foam tape along any seam that touched the plastics bits and 100% of the noise disappeared. The bronco is next when I get some free time.
incavulator
Mine is doing the same thing. In my case, it's coming from the window switch panel on the driver's door armrest. Those clips are junk and when I bought the vehicle, a couple were broke and fell down inside the door panel. I removed the door panel to get rid of the pieces rattling around in there, and replaced the clips with new ones. It helped a lot but still rattles some. I'm planning to do the same thing with that fine felt material.
mok968
mok968
NB | Canada
Thanks guys. I was thinking of taking it to the dealer here. Otherwise I may open the door panel myself and see what the issue is. Is it difficult to open the panel?
incavulator
If it's under warranty and you're not comfortable removing it, I'd take it to a dealer you trust.
If not, I didn't think it was too bad to work on yourself.
mok968
mok968
NB | Canada
Thank you all for your advise and help. Really appreciate it! :)
