- First Name
- Louis
- Joined
- May 26, 2023
- Threads
- 3
- Messages
- 35
- Reaction score
- 39
- Location
- Central Minnesota
- Vehicle(s)
- 2023 Outer Banks, 2013 Mustang Convertable
- $15.00 free shipping
- 1 REMOVE INSTALL HANDLE, 1 ADAPTER AND 6 PLUGS. Dsnaduo Oil Drain Plug 8 Pack Compatible with Oil Drain Plug Removal Tool. Oil Drain Plug Removal Tool Suitable For Oil Drain Plug And Used To Loose And Tighten Of Oil Drain Plug. When Use The Removel Tool To Loose And Tighten The Oil Drain Plug, Will Help To Work In Suitable Way Easily.
- Oil Drain Plug Can Replace BC3Z6730A, BC3Z6730B, FT4Z6730A, KX6Z6730B, FT4Z-6730-A, KX6Z-6730-B, BC3Z-6730-A, BC3Z6-730-B, 097-826, 097-826CD, 097-826.1, 097826, 0978261, 097826CD.
- The Plug Use Same High Quality PA66 Material As The Original Materials. PA66 Material Is With High Corrosion Resistance And Long Service Life Compared To Other ABS Material Products On The Market.
- Dsnaduo Oil Drain Plug Is Designed And Constructed To Strict Engineering Quality Standards. There Is Clear Install Description On The Plug. This Oil Drain Plug Drain The Oil From Your Engine Oil Pan During Oil Changes Easily. The Green Oil Seal One the Plug Prevent Oil Leakage Effectively , And Preventing Dust Particles, Road Debris, And Other Contaminants From Entering Your Tank Or Oil Pan.
