Is this a valid pass thru for power and RG58 antenna cable
jnot2
james
virgina
2022 Hot Pepper Red BadLands
There is a rubber grommet on the drivers side door on my 2022 Badlands. I haven't been able to verify yet if this will work as a pass thru for power and RG 58 antenna cable. It is the one circled in blue in the picture. Has anyone looked into this yet.
Ford Bronco Sport Is this a valid pass thru for power and RG58 antenna cable bronco sport drivers door 2
Geelloo90042
Angelo
Los Angeles
Not sure if that's the same location. I used the pass thru under the brake reservoir. It has a nipple on it that you can "slice an x" to pass wire thru. It's a pain and have to remove the battery and air filter box to get to it, but it worked.
