4wp lift cheat code?
Saint D
Matt
24 maverick and bronco sport
I just picked up a 4wp lift on eBay for $75! Has anyone just used the front spring spacer or just the front strut extension to pick the front up half the intended lift amount to just simply level their bronco instead of installing the complete lift? I’ve seen just the front complete lift installed and it makes the front taller but I wonder if just half of the front would level it?
I believe I've only seen a couple of posts where people installed the 4WP leveling kit. From what I read they didn't go into the details of how the install was performed.
I would imagine the kits were installed per the instructions using all the parts..
The 4WP lift is 1.0" for the front and 3/4" for the rear.
You can measure the spacer height for the front struts, if it's approximately an inch in height it must work with the spring preload spacer to limit the struts sag and lift the front the full inch.
Ford supposedly used the 4WP kit early on for the Bronco Sport Off-Rodeo support vehicles, they were running 30" tires.
