Weird Knocking/Grinding-ish Noise
musicman1700
Ian
Nevada
2021 Bronco Sport Base
So I recently purchased a bronco sport base model. Everything was fine for the first 200 or so miles but this grinding noise keeps coming up every time I accelerate and let go of the gas pedal. I feel like it may be the turbo but I’m not a mechanic unfortunately..I took it to the dealer and they said as long as it’s not affecting the drivability that I shouldn’t worry about it. Should I worry or not?? HELP!!
omahafordowner
Nebraska
Ford Flex
Correct, you should always ignore warning signs of something possibly being wrong until something actually breaks and you get stranded on the highway.
I suggest you take it for a second opinion.
musicman1700
musicman1700
Ian
Nevada
Should I take it to another mechanic or back to the dealer?? My only concern is that with the dealer they’ll just leave it and say nothing is wrong..
ZeroCool
Oh
Absolutely take it in bro. I had a loose shift cable that was rattling around and it sounded awful but wasn’t a big deal. Dealer heard it, fixed it. Make an appointment, let them take care of it, and love the new ride.
ZeroCool
Oh
I would take it to the dealer you bought it from. I ended up taking mine to a different one simply because my dealer that I purchase from was an hour and 20 minutes away but the dealer people were nice, and they drove the car and heard what I heard and they fixed it.
musicman1700
musicman1700
Ian
Nevada
What did the loose shift cable sound like??
musicman1700
musicman1700
Ian
Nevada
Sometimes rattling sometimes grinding, I think probably related to vibration of engine at different rpm. I also noticed it around the same point you did. Very early on. Here this is what I got from the dealer.
Ford Bronco Sport Weird Knocking/Grinding-ish Noise 13CA32E8-E0D1-4980-A91E-7448CF97E755
This is exactly what I needed! Thank you so much!
perfect! Thank you so so much for your help! One more question. Was it only on certain gears or was it throughout the whole shifting pattern?
ZeroCool
Oh
Just like the paper says acceleration deceleration 1 to 3000 RPM.
steelerfanellie
Ellie
Goodyear, AZ
steelerfanellie
Ellie
Goodyear, AZ
I'm having the same issue, a loud grinding noise twice when sitting at red light yesterday. This also happened a few days ago when I was stopped, and put vehicle in reverse to back into my garage. Sounds like a tranny issue and seems to happen when I have the anti-spam function turned off. It is loud and sounds like gears grinding.
I didn't have this occur until after a few months of driving it, about 800 miles. Any advice?
You need to find another dealer asap. Simple test drive another new one. If it don’t do it you got your proof but still your dealer allowed the service department to drop the ball.
Move up the chain of command !
FWIW, My Base model has more than 15,000 miles on the clock. It’s really really quiet,
I gave the same problem. Absurd crunch sounds, generally at lower speeds and turns.
Good Morning! If you could send us a Private message with your VIN and dealership name and location, I would like to look into your braking issue.
AlpharettaOuterBank
kdawg
Georgia
Outer bank
what was the result
