Vehicle lost it’s acceleration power
Keepsie
Keepsie
BroncoSport
Hi all,
Today while am driving on the freeway all of sudden my vehicle lost its acceleration power, while pressing the gas pedal it’s making sound but the vehicle moved very slow. I didn’t got any warningsTook an exit turned off the vehicle and started it came back to normal.
This is the first time I faced this issue for driving more than a year and half. I have full gas and my engine oil is due this week. Would like to know what could be the reason. I have warranty do I need to mention the issue at the time of oil change? Please pour in your suggestions and advices.
Thank you.
BLUEOVALRACER
It could be Possible The Tubing for the Turbo came loose and you're losing Boost. So after you shut it off and started it again it ran fine?
Keepsie
Keepsie
BroncoSport
Did you notice if the tachometer was moving as you pressed the accelerator pedal?
I would definitely discuss this issue with the service advisor.
Yes it was moving, ya I will inform this at the time of service.
Keepsie
Keepsie
BroncoSport
Does that mean it became loose or something? Do I need to look into it or it’s automatic?
Tomp611
Maryland
2022 Bronco Sport Big Bend
Did you check to see if you are part of the just expanded battery recall?
Keepsie
Keepsie
BroncoSport
One battery recall was fixed. I don’t know if there’s any new recall.
Omar Leaf
Omar
this happened to me while I was parked thank goodness I wasn’t driving, I was just parked and my car just shut off. So I turned it back on and it ran normal after that. Then I checked and yes, I am part of that recall unfortunately.
BLUEOVALRACER
Is it still not running right? I know on the F-150 Forum some guys had issues with the Tubes coming off or loose and losing boost and not running right.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
That would be the first I've heard of a sport popping a charge pipe or turbo coupling. I doubt it's this if it's driving like normal again. You definitely feel the difference with a charge pipe off the intercooler. And would manually have to put it back on.
Hi all,
Thank you.
Any update on this issue?
