- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 101
- Messages
- 5,310
- Reaction score
- 9,977
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
You can use engineering test mode to adjust the average fuel economy bias (AFEB) number the computer uses to compute and display mileage. If your car is like mine, you may have noticed the displayed mileage is significantly different from actual. I've been manually tracking fuel economy since I purchased the vehicle in Nov 2021 (see this post). Here's a link to the tracking spreadsheet I use; you can see displayed fuel mileage is consistently higher. By adjusting the AFEB I hope to make the displayed mileage more accurate. Here's how to do it:
To determine what AEFB number to use you must first hand-compute fuel mileage over several tanks. The owner's manual recommends at least three full tanks to average out all the possible variables. I would make sure you are using the vehicle for its typical mission while hand-computing over these three tanks, i.e. don't measure over a long highway trip unless that's what you typically use the car for. I would reset one of your trip meters on the first fill up, then do not reset it until the third fill up. Keep track of how much fuel you put in at each fill. After the third fill you should have the total miles driven along with the computer's estimated fuel mileage for that trip.
Once you've hand-computed your mileage you'll compare it to the computer's estimated mileage. Divide your actual mileage by the displayed mileage to get a correction factor. For example, my lifetime mileage (TOTALS tab on the spreadsheet linked above) is 26.62. My average indicated mileage is 27.3. If you divide 26.62 (actual mileage) by 27.3 (displayed mileage) you get . 975. This number means my actual mileage is 97.5% of displayed mileage.
When you first see the AFEB page it should be set to 1.000. You'll use the up/down arrow keys to change it to whatever number you get after your computations. I set mine to .975. I'll give a couple of tanks to adjust to the new AFEB number and report my results. Watch this space...
- Hold the "OK" button on your steering wheel and start the car.
- Hold the button until you see "Engineering Test Mode" in the center display (between speedo and tach), then release the "OK" button.
- Press either of the up/down arrows until you see the AFE Bias page.
- Press the "OK" button to enter edit mode, then use the up/down buttons to adjust the number.
- When the number is set press the "OK" button to save it.
- Shut off your car to exit engineering test mode.
NOTE: I am not a Ford technician, but I suspect there are other settings in this mode that if changed can impact the way your car operates. I would avoid dinking around with anything in there unless you know what you're doing. Obviously, any changes you make, including to the AEFB, are done at your own risk.
