Do you know if your dealership installed ceramic pads?Dealer put some fresh pads in this morning and cleaned the rotors. Will see if its better over the next few days.
I asked him that question, I think they put the exact same kind back in, he told me ceramic would be more likely to squeal vs semiDo you know if your dealership installed ceramic pads?
Would you happen to have a part number for the Ceramic pads? If there even is a ford one. They are still writing up the paperwork to warranty it with Ford, as Ford wanted to close it out as a "wear" item / no problem / cosmetic issue.Suggest you do a search for ceramic on this forum.
āceramic brake pads, are quieter, are able to handle extremely high temperatures with quick recovery, causing less damage to the brake rotors, ceramic brake pads create a finer dust than semi-metallic brake pads leaving less debris on the vehicleās wheels, typically last longer than semi-metallic brake pads, provide better noise control and less wear-and-tear to brake rotors, without sacrificing braking performance, Note: not all vehicles are compatible with ceramic brake padsā
I collected some info but havenāt confirmed the links and part numbers I have are correct ⦠my ā22 Badlands just started a light moan noise in reverse a few months ago and the sounds lasts no more than a second so not enough of an issue.Would you happen to have a part number for the Ceramic pads?
Brake squeal occurs due to a number of factors, only one of which is pad material. It could be the pads themselves making noise, the rotor, or a resonance generated by multiple components. Changing pad material can sometimes eliminate brake squeal by changing the way components in the system interact with one another.Suggest you do a search for ceramic on this forum.
agree 100%.Brake squeal occurs due to a number of factors, only one of which is pad material. It could be the pads themselves making noise, the rotor, or a resonance generated by multiple components. Changing pad material can sometimes eliminate brake squeal by changing the way components in the system interact with one another.
The bottom line is unless you know for a fact what is causing the noise switching to ceramic pads (or any other material) may or may not eliminate the noise. It might make it better; it might make it worse.
That was not the intent of my post .. the OP stated āI think they put the exact same kind back in, he told me ceramic would be more likely to squeal vs semiā.Brake squeal occurs due to a number of factors, only one of which is pad material. It could be the pads themselves making noise, the rotor, or a resonance generated by multiple components. Changing pad material can sometimes eliminate brake squeal by changing the way components in the system interact with one another.
I was responding to the quote you included in your post regarding ceramic pads. If you're asking whether I think ceramic pads are more prone to squeal than other types I would say for all the reasons I posted, without testing it's not possible to state definitively whether ceramic brake pads are more or less prone to squeal for a given application. I see three possibilities regarding the technician who told @bclarke68 ceramic pads would cause more squeal. The technician:what are your thoughts on that specific topic?
Ford came to my house and did the bushing and pins back in September or October and has been fine since , oh yes donāt forget to put some silicone grease on those pins. Then again I know of someone whoās dealer put new rotors and pads all around and the next day it made the same noise. I think ford is still trying to figure it out.I was responding to the quote you included in your post regarding ceramic pads. If you're asking whether I think ceramic pads are more prone to squeal than other types I would say for all the reasons I posted, without testing it's not possible to state definitively whether ceramic brake pads are more or less prone to squeal for a given application. I see three possibilities regarding the technician who told @bclarke68 ceramic pads would cause more squeal. The technician:
IMHO, those are in order from most to least likely.
- was bullshitting to shine on a customer asking a legit question.
- doesn't understand what causes brake squeal and was bullshitting to cover their ignorance.
- has tried ceramic pads to fix this issue on another Bronco Sport and the squeal got worse.
For anyone who doesn't really understand what causes brake squeal, this video from Porsche is enlightening:
This. As noted in the video I posted previously, there are so many factors involvedāmaterial, mechanical, environmental, etc.āit's nigh impossible to determine precisely what's causing the noise. And often, what works to eliminate noise for one vehicle in one climate may not work for another.I think ford is still trying to figure it out.
Good to know, makes perfect sense . At 72 years old and I have been a car guy from age 16 years old ,working at a garage after school. That is some very informative information. Thanks for sharing your knowledge . JimThis. As noted in the video I posted previously, there are so many factors involvedāmaterial, mechanical, environmental, etc.āit's nigh impossible to determine precisely what's causing the noise. And often, what works to eliminate noise for one vehicle in one climate may not work for another.
The fix that has worked most often for me is two-fold: liberalāand I mean LIBERALāapplication of grease on moving parts (guide pins*, caliper glides, etc.) coupled with anti-squeal countermeasures on the backside of the brake pads. Countermeasures can be rubber pads, rubber-covered metallic shims, or even high temp grease applied directly to the backside of the brake pad.
* Do not apply grease to the ends of guide pins. Grease is not compressible; if you get grease in the guide pin slots it can prevent the guide pin from seating fully in the slot, which can interfere with brake operation (see video below). Brake systems are not particularly complicated, but you can endanger yourself and others if you don't know what you're doing.
