Tow package removal
YFD_322
scott
NY
2021 Rubicon
I don't need or like the tow package look but I'm finding more with the package than without. Is there any special cutouts to the rear bumper or valance that if I remove the hitch there will be a void or something to the rear saying that there was a tow package on the vehicle?
Advertisement
Davenorton
Dave
Saratoga Springs NY
2007 xterra, off-road..21 badlands on order
I am adding the tow package, after the order was submitted, I think the added flexibility is worth it. I should have plenty with the 2250 load limit to do what I expect.
Zolutar
Trevor
Sea to Sky, BC, Canada
2017 Escape Titaniuim, 2021 Bronco Sport OB+
think of resale value, that helps down the road. But I can see your point.
Being factory built, its quite integrated with the frame. I could very well be removed, but not a simple "remove a couple bolts" kind of task, I believe, and a replacement bumper cover for the hole that would remain.
Better and cheaper options would be to find a good bumper cover., simple caps, to an extra brake light or even a functional step.
Just buy the step that they already do make for the tow insert. That would make great use of the hitch. Seen it on our post somewhere.
YFD_322
scott
NY
2021 Rubicon
  • Thread starter
  • Thread Starter
  • #7
ok if it’s that much trouble then if I get one that has it I’ll just keep it. It’s fine I guess just wanted clean look back there. Thanks.
TheMalamute
Matt
Kentucky
2015 GMC Canyon
I like this. The tow capacity in these are incredibly small. Ultimately I like the hitch because it provides security for the bumper. Have owned a lot of trucks and when I had a hitch installed, it saved the vehicle a lot of damage...
YFD_322
scott
NY
2021 Rubicon
  • Thread starter
  • Thread Starter
  • #9
that’s a good point
tuolumnejim
Stagecoach, Nv.
If you were closer I would have swapped my bumper cover with you, I need the hitch.
Baracuda6
Alex
Man i wish I had this problem. Tow package was on my list but didn’t come with my BB package. I’m in Nj so if you’re still considering I would gladly swap with you
thesavo
savo
Albany NY
2008 Mariner
Tow is an add-on to all trim and packages. It doesn't come with any of them.
Advertisement
