- First Name
- Mace
- Joined
- Jan 20, 2021
- Threads
- 10
- Messages
- 61
- Reaction score
- 202
- Location
- LOS ANGELES
- Vehicle(s)
- 2021 Bronco Sport
Hey all
For a few days I've had problems with my Bluetooth connection with my sync. I tried following all the protocols. Deleting / unpaoring the the device on my phone, restarting my phone, tried to delete phone off SYNC and wouldn't, and so went as far as a master resetting in SYNC.
As soon as I repaired my fordpass everything went back WITH ALL THE PROBLEMS. No connection with my phone and it still showed up but no commuting between my phone and SYNC. So I did a little research and found that others had problems with this on the SYNC.
Everyone had Success with pulling the fuse that connects to the snyc.
Solution:
Find the passenger side fuse box
Find fuse #17 - SYNC, Receiver transceiver module, Integrated control panel (mini 15amp)
Pull it out and wait a few seconds
Then put it back in and it works!!!!
I hope you find the same success if you come across this.
It was hard to pull the fuse out without a fuse pull tool but its doable.
Also here's a link to all the fuses in the hood and passenger compartments
https://www.startmycar.com/ford/bronco/info/fusebox/2021/trims-sport#anchorfusebox1
Solution:
