Definitely gotta post updates and pics when you get it. I was looking at the same thing.![]()
I just ordered one of these for our BL. They are shipping beginning of June so at this rate I should get tent and vehicle at the same time![]()
i'm interested in what you learn!Definitely gotta post updates and pics when you get it. I was looking at the same thing.
I have no problem with a little over hangWhy did you order this? It's 90" long. That's way too big for the bronco sport.
It should fit perfectly. It might be slightly longer than the roof surface, not way longerWhy did you order this? It's 90" long. That's way too big for the bronco sport.
It’s not necessary to avoid loading the roof above the antenna. It is designed with bendable material.If you move it up enough so that the antenna is not squished, it will be over hanging the windshield a good bit.
I’ve heard the fin style is the Canadian version. Not sure about that though. The stick style is a bendable stick... that is made to bendNot that I am worried about the antenna,
but I have seen 2 different antennas on the BS. A fin style and the stick style.
any thoughts on differences. ( if you zoom in this has a fin antenna)
Of course you can load over it, but it will impact the performance of the antenna and associated equipment. As you can see in the picture, that tent folds up and stops blocking antenna when you are on the move. Roof rack in OP would provide no such relief while moving from A to B.It’s not necessary to avoid loading the roof above the antenna. It is designed with bendable material.
Thread starter | Similar threads | Forum | Replies | Date |
Rooftop Tent or Sleeping Inside | Off-Roading, Overlanding, Camping | 8 |
Similar threads |
