Spare tire addition.
BBBronk
Va Beach
2026 Ford Bronco Sport
So prompted by reading another thread about cargo mats I came to realize I have no spare tire. I want a spare tire. An air pump only helps for slow leaks. Anything else require a $150 tow and then I still have to spend $200 on a tire. Then there is just the shear inconvenience of it all. I couldn’t find all the answers I needed through search. (Not without reading for 3 days straight) So first my specs and then my questions. 2026 Bronco Sport Big Bend. 1.5ā€ lift with optional 245 65R 17 tires.
1. What is the spare tire size? (That fits properly underneath the mat)
2. Will a spare tire even help me with the increase tire size and lift?
3. In the posted pictures, the foam under the cargo mats is held in by a plastic piece in the center. It does not appear to unscrew. Do I just yank it straight out?
4. Do they sell a replacement foam that fits along with the tire? (For a scissor jack and spade) No tire will fit with what I have under there currently.
Thanks
Ford Bronco Sport Spare tire addition. IMG_4374
Ford Bronco Sport Spare tire addition. IMG_4373
BBBronk
BBBronk
Va Beach
For what it’s worth, when I was shopping I assumed a spare was under the grayish mat under the foam. That’s on me. Caveat Emptor!
2025 Badlands Sasquatch
The "full-size" spare is 225/65R17. As far as the proper foam, try finding a Badlands at a wrecking yard, that is the only trim that has always included a spare for its entire run (AFAIK).
BBBronk
BBBronk
Va Beach
Thanks for the reply. Do you know the mini spare tire size?
SWUKU
GB
KY
mine came with a full size Pirelli scorpion as a spare. It fits perfectly. Why use a mini?
Garth
Garth
Ontario
Yes if you can find everything at a wrecking yard assuming the tub area is the same, I cant imagine them going to the expense of manufacturing different sheetmetal just to skip the spare.
I don't know that one. One of the other members would have to chime in if they've got a donut (which, TBH, I'd avoid if possible).
BBBronk
BBBronk
Va Beach
I ask because I am not sure I can avoid it. I am getting conflicting information on whether the full size spare fits or not.
North_of_49
Glenn
Edmonton AB Canada
Yeah I’ve been wanting to know the doughnut size as well cuz my 2025 Outer Banks just has the inflation kit. I test fit the doughnut from my neighbour’s Edge and it fits in the space fine with floor board flat as it should. I seem to remember someone said with a full size spare the floor board doesn’t sit in its low flat factory position.
No reason it wouldn't, given the correct foam insert. I can't imagine different stampings just for that. If you had a BB or OB with the tow package, it got a full-size spare, and all BL have them. Older BB/OB had a donut for weight & cost savings, but was changed to the inflator kit for the '25MY.
Iamcanadian
Jason
Ontario Canada
I could be wrong but I do not believe any of the broncosports came with a temporary spare AKA mini spare. I'm pretty sure the only options were either a full size spare or the inflator kit. At least that's what I came across when I was looking to purchase my vehicle. Somebody correct me if I'm wrong.
Edit: after checking on the Ford site, I see that the 21 to 24 models did come with a donut if they didn't have a full size spare. I guess the reason I didn't see this when I was researching was because I was looking at 2025 models which have now done away with the donut for cost & weight savings
The floor does sit at the upper position with a full size, lower position with a donut or inflation kit.
BBBronk
BBBronk
Va Beach
Thanks for those most recent replies I think I have found the reason for the conflicting answers. Floor must raise up for the full size spare. That is worth the trade off to me. A tire company told me there was no donut listed for the 25 and 26 and now I know that is accurate also. Thanks guys!
North_of_49
Glenn
Edmonton AB Canada
Ok thanks. I may want to sleep back there when I take a trip to the mountains in Canmore or Banff instead of paying $300 a night for a hotel room like I was doing with my Escape, so I’ll probably opt for the doughnut to keep the floor low. I’ll need to figure out the largest diameter doughnut I can fit in there since my tires I upgraded to are a tiny bit oversized at 245/60/18. Stock on the 2025 OBX is 225/60/18 so about 3.3% larger if memory serves me.
BobbyTony
Bob
Soon: 2025 BS OBX Now: 2019 Edge Titanium, 2014 F150 XTR, 2006 mustang GT
If you wanted to go to Canmore next week, you could finish my week for less than $300/night! Lol. (Just found it funny to see the note as I was reading through and as I realize I didn't set up my life to stay a whole week at my resort condo 😭)
