Seat Manual Section Request
Steven 6095
Steven
Kentucky
Good afternoon. I broke the driver's side outer seat cover; the plastic trim down where the seat adjustment is. (LJ6Z-7862187-LA)
It's not too expensive, but I'm having trouble getting it off.
Would anyone have a moment to share that section from the service manual?
Thank you very much for your time,
Steven
Ford Bronco Sport Seat Manual Section Request 1756139953002-mn
Steven
@Steven 6095 Can you please post how you got the broken part off and installed the new LJ6Z-7862187-LA part?
@rugedraw
I located the 2 part #s shown below for the drivers side seat - plastic cover both parts say they fit a 2022 Bronco Sport Badlands
Does the Ford info you have access to state that N1PZ-7862187-LB is the up-to-date revised part? I can message you my VIN# if you need that to confirm that I should purchase the N1PZ-7862187-LB part.
Outer Cover, Ford
Product ID: LJ6Z-7862187-LA
Outer Cover, Ford
Product ID: N1PZ-7862187-LB
The plastic cover is prone to breakage so I would hope the revised part maybe is a stronger more reliable part but that’s just me hoping
Also, do you access to the installation instructions? The prior post shows that the drivers seat should be first removed but a cursory look says that should not be necessary?
Ford Bronco Sport Seat Manual Section Request IMG_1599
rugedraw
Javier
Miami, FL
@rugedraw
Outer Cover, Ford
Outer Cover, Ford
In this case, I cannot be of much help. The access I have to PTS/OASIS is for a sales job role, so I am limited as to what I can see on the service/parts side of the website. The parts catalog is one of the things I cannot access. The section that shows you how to remove that piece does not show any part numbers, but in case it helps, here you go.
Edit: Didn't notice it was posted before.
Edit #2: Or, remove the part your truck has on it now, see what P/N it has and order the same one.
Thanks for the installation instructions!! Appreciate that!!
Are you sure that is for a 2022 Bronco Sport? The PDF that you attached says 2022 Bronco and shows a Bronco in the pics
Ah, maybe I grabbed the wrong folder. I have both sets of PDFs. I'll just delete the attachment since someone posted the other version.
The section that shows you how to remove that piece …
that section refers to:
Remove the front seat.
Refer to: Front Seat (501-10A Front Seats, Removal and Installation).
if not a lot of trouble can you please post the 501-10A Front Seats, Removal and Installation PDF?
rugedraw
Javier
Miami, FL
If I don't get on my laptop tonight, I'll post it tomorrow when I get to work.
It's remarkably like the wrong PDF I put up, but with a Sport line drawing. Here's all the Front Seat PDFs for section 501-10A, since invariably Google will eventually send someone here.
