Removing the door handle covers
fastlax16
Chicago
I’m trying to remove a body panel to bring into Home Depot so I can get it color matched for some house paint. Has anyone removed the door handles? Seems like the easiest painted trim piece to get off. The other candidate is gas cap cover but that doesn’t seem to come off easily.
brockdog12
NTX
There are posts on here on how to remove the door panels, someone removed theirs to paint the trim to match the arm rest on the door, you can search them up.
Might be easier to get a bottle of touch up paint and match to that.
fastlax16
fastlax16
Chicago
it would except I need it by tomorrow andcactus gray is special order. Failing to plan is planning to fail and all that jazz.
SWUKU
GB
KY
Google it
My FE is Area51, and Google found it is also called KU on other Ford products.
You may be able to find the RGB mix, or the PMS (pantone matching system) #
Legacy40k
Andrew
Ontario
Velocity Blue Bronco Sport
Why not just grab the paint sample chips that look close, walk them out to your vehicle, and pick the one that is closest?
PonyDriver43
Roger
NE FLA
Gas filler door might be easier.
NVSport
Paul
North Vancouver, BC
2021 Bronco Sport & 2015 Mustang GT C/V
You might be able to pop the key hole cover off the door handle easily, check the manual. I know the one on my pony car does.
