rear tires uneven wear?
Soltzrm
Rose
Akron
Ford Bronco Sport, VW JEtta, Audi A5 Cabrio
2021 Badlands 15K mile service, uneven wear on rear tires only - noticing vibration at higher speeds on interstate.
No alignment issues, tires are balanced. What's going on here?
Factory Installed tires ?
My Continentals with the cool Bronco horse on the sidewalks were total crap hydroplaning killers at 12,000 miles.
Just saying,,,,
Maybe a bearing or suspension joint going?
BoxerBronco
Aaron
Alignment…and yes I read the first post lol!
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Soltzrm
Rose
Akron
just had alignment checked by reliable technician at oil change....all green lights. must be poor original tires or a suspension issue, I guess
Benanza
Ben
NJ
Just saying,,,,
Continental logo has a front kicking horse, it's not actually a bronco logo.
Ford Bronco Sport rear tires uneven wear? download
Benanza
Ben
NJ
How often do you rotate the tires, cause it really sounds like an alignment issue. Reliable or not, some service guys are to busy to care at times, saying alignment is fine gets you to pay the bill and go.
Soltzrm
Rose
Akron
Saw the documentation on alignment, we take all of our vehicles to this technician…and have for 15 years. Concerning issue w/this vehicle
CrashBend
How frequently (miles) did you rotate your tires? I had a similar issue with a Honda CRV with rear tires. With that car the tires wore uneven because I was not carrying enough weight in the back to push down on the suspension. With more frequent rotations I did not end up with two tires worn more than the others. I am rotating tires now on our O.B. at each oil change, 5,000 miles.
Zolutar
Trevor
Sea to Sky, BC, Canada
OEM Michelins are crap. at 4/32 at 28700 kms....so what's that, barely over 20000 miles? Alignment all within spec. relatively even wear across the tread and some splitting happening in the tread too, Michelin Rep took em for evaluation. We shall see the verdict here.
seoden88
Scott
Louisville, KY
'22 Bronco Sport Badlands
bro this tire was from months ago. please dont reply to super old threads
AC AL
Alan
Belmont Ca
71 Bronco, 2021 Bronco Sport
Did you ever find out what caused the wear problem?
I also have a 21 badlands with excessive wear on the outside edge of both rear tires. I rotate my tires every oil change @ 5,000 miles. 23k on the car now
Thanks
jkeaton
Greatest country on earth!
This one
Thanks
Alignment is always a good place to start for uneven tire wear. Also realize OEM tires are not designed to last. They are not the same as you or I can buy even if they have the same name/model.
