Question about the "my view" in the instrument cluster.
airems
Jeff
Show Low AZ
I have 4 screens chosen. When I add the tire pressure screen it only stays for a couple days, then I have to go into setting and add it again. It that normal or does mine have an issue? 2026 BS BL Sasquatch. Thanks!
2025 Badlands Sasquatch
I have 4 screens chosen. When I add the tire pressure screen it only stays for a couple days, then I have to go into setting and add it again. It that normal or does mind have an issue? 2026 BS BL Sasquatch. Thanks!
It’s a common issue. Mine does it randomly every few weeks to a couple months.
alank2
OK
Ford Bronco Sport 2025 Big Bend
Mine does it too. Not sure why it doesn't remember. I'm surprised when it does.
BBBronk
Va Beach
2026 Ford Bronco Sport
Isn’t it just awesome that something called “my view”, because it is what you want, should actually be called “Ford view”, because it’s what they want. 🙄
alank2
OK
One would think the basic thing about MyView is that it would properly remember my view settings...
North_of_49
Glenn
Edmonton AB Canada
Yeah mine randomly deletes tire pressure, Trip 2 and adds the degrees level thing that I don’t want.
RC Turner
Southern Minnesota
Common issue that I have had on several of my Fords. Dealer says that they are not aware of any fix. Ford doesn't seem to care.
Murrow
Atlanta
2025 Ford Bronco Sport
Yeah, it's a common complaint. Mine's going in tomorrow, and it's one of the things they're going to need to get on the record -- again. Dealer said the cluster recall should have fixed it. It didn't. Considering how widespread the issue is, Ford obviously knows about it, but is either unwilling or unable to fix it.
In March, I started keeping a log of the resets. The resets always used to reset my oil life monitor as well, but now it seems to be doing that less. Here are the dates I've noticed. I'd be curious if other people are somehow finding it happening on the same dates.
3/3
3/25ish
4/1
5/1
5/15
6/9
6/15
6/18
7/7
7/8 (included oil reset)
8/10
8/12
8/17
Another thing I don't get is why the default isn't for EVERYTHING to be checked -- especially tire pressure. It's just a dumb software decision in a car I find is full of dumb software decisions.
Unicorn
Chester
W. WA
2025 BS Badlands with Sasquatch.
Mine does it too sometimes. Also the two gauves that only show up in sport, offroad, sand, and rocks crawl. I change it to transmission and oil temp and eventually it resets to turbo boost and voltage.
I do so wish that thkse were on every mode.
