Power window control
fpizzo80
Francis
Mesa, Arizona
2022 Ford Bronco Sport Outer Banks
I have a 22 Outer Banks. Does anyone know if the front passenger power window control can be controlled by the driver's side lock switch? I want to be able to lock the windows so i can control it from the driver side. I asked the dealer where ii bought the Bronco Sport and he said no .
If I understand your question correctly, you want to lock out the window control on the front passenger door so that it can only be opened and closed using the control on the driver side door. If that's the case it appears you dealer is correct. The owner's manual refers to locking out only the rear door window controls, not the front passenger window control.
