passenger front carpet soaked
DAN PAVLICK
DAN
CT.
2021 BRONCO SPORT
was vacuuming carpets and noticed that the passenger front carpet was completely soaked. i have been running the air conditioning a lot is that the problem?
there was no water anywhere else. the wettest area is 2" above where floor mat buttons to floor? anyone else have this problem?
AndyMac204
Andy
you park under alot of trees?
sometimes there is a air conditioning drain tube that can get plugged and cause this. not 100% sure on BS, but def seen it in other makes/models
vxarctic
If you haven't left your vehicle out in the rain or near sprinklers - is your windshield wiper fluid levels low? Definitely take it in to the Dealer to have a look.
DAN PAVLICK
DAN
CT.
2021 BRONCO SPORT
don't park under trees. glove box and upper part of carpet completely dry
Kind of a wide open question for us to guess. First figure out if it's water, coolant, windshield fluid or something spilled. If it's just water, could be it's a rain leak. If it rained where you are. Could be a faulty window seal or door seal or a sunroof issue, but we don't even know if you have that option. If it has coolant, someone didn't tighten a heater core hose. If it's fluid, could be an issue with the reservoir or the line that goes to the rear.
DAN PAVLICK
DAN
CT.
2021 BRONCO SPORT
no sunroof. did not spill anything in car, and there are no traces of leaks around windows or door. i'll check the washer fluid but it appears to be water. carpet is wettest 2" above button for floor mat
fourthgear
florida
First thing I would have looked at is the Condensate drain tube for the A/C , see if its dripping water on the ground when running . If you don't see it dripping , it's probably plugged to kinked or something else with it . Take it in its under warranty , just in case it's something odd .
Trailrunner916
Celia
What wait!! Do you have full carpet or just the carpeted mats?
rms34208
Ford Escape 2013 SEL
I thought all BS had rubberized floors, not carpeting.
DAN PAVLICK
DAN
CT.
2021 BRONCO SPORT
okay thanks. i checked the wiper fluid in the car and that was full. it's strange because everything is dry except the bottom of the carpet. where would the condensate tube be?
