Odd hoses one leaking fluid next to battery 2.0L 2025
Putter Boy
Jonathan-Boyd
Pinehurst, N.C. 28374
I noticed tonight while looking for my Aux wires this odd hose next to the battery that connects to nothing and leaking or dripping a fluid that looks like oil but not very oily, then next to it is another hooked to nothing as well not leaking at all. ????
Ford Bronco Sport Odd hoses one leaking fluid next to battery 2.0L 2025 IMG_2554
Anyone know what this is.....
oily. See photos attached.
Ford Bronco Sport Odd hoses one leaking fluid next to battery 2.0L 2025 IMG_2551
Ford Bronco Sport Odd hoses one leaking fluid next to battery 2.0L 2025 IMG_2564
Ford Bronco Sport Odd hoses one leaking fluid next to battery 2.0L 2025 IMG_2558
Putter Boy
Putter Boy
Jonathan-Boyd
OP said there are two unconnected hoses, one being from the transmission vent / fill port but what’s the 2nd unconnected hose?
Putter Boy
Putter Boy
Jonathan-Boyd
After some research it is the front differential vent.
Putter Boy
Putter Boy
Jonathan-Boyd
I'll tell you, my stuff is routed differently than yours so your pic doesn't look the same as mine would. The gooseneck means that's a vent. The other rubber vent hose I have near the battery is back closer to the firewall, clipped to another hose, and it goes down into the depths of the engine. It's some sort of a vent for the crankcase or the oil pan. Maybe the oil separator? I don't know which side of the engine that's on.
BLUEOVALRACER
Is your BS BL a 2025?
